kJams for Windows is OUT!!
Go Get it!!! kJams for Windows
Re: kJams for Windows is OUT!!
I have a backup of my kJams folder from my Mac on a Network drive so is there an easy way to copy the music back down to my Windows machine to avoid re-importing and retain the metadata, playlists, etc?
just copy the "kJams" folder to your Music folder on your PC, should be good to go!
That's great, but it won't even start...have Vista Home SP1 and tried the pro version. When I double-click the exe, I get a crash immediately (nothing pops up but the crash).
Got this error signature upon starting:
Problem signature:
Problem Event Name: APPCRASH
Application Name: kJams Pro.exe
Application Version: 1.0.51.0
Application Timestamp: 4c27c663
Fault Module Name: CFLite.dll
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 4c25aa2e
Exception Code: c0000005
Exception Offset: 0008fcb6
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 1033
Additional Information 1: e888
Additional Information 2: 39ebc9914444511f2943288f165c1a39
Additional Information 3: c417
Additional Information 4: 2ccee9360be3cfb3f34359a8b6b5d9e1
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0409
Problem signature:
Locale ID: 1033
try the NEW new release. note: always look for an update before reporting a problem.
if there is still a problem, please contact me directly so we can figure it out. i can't diagnose the problem on a BBS
Is there a NEWer release than what you linked to on your site???? NOTE: There are NO UPDATES for Windows listed on your site. I'm not a newb at this. Since you say you can't diagnose on the BBS, why don't you tell me what other info you'd like??????????????????? I already emailed you through your site (but haven't received a response).dave wrote:try the NEW new release. note: always look for an update before reporting a problem.
BTW, the lite and pro vesions both crash.
i make new releases sometimes every day. i just made one this morning. when did you download it? release notes are on this page.
http://karaoke.kjams.com/wiki/History/1 ... st_Changes
what other info i'd like is to see your screen, to do screen sharing, so i can DIRECTLY FIX your problem, which we can only establish if you contact me directly, not on this BBS.
i have in fact responded to you but you have a yahoo address and they block me because they think i'm a spammer. you can help by complaining to yahoo that you're on an OPT-IN list from me and you WANT my emails. i've been negotiating with them for 48 hours with no resolution yet.
meanwhile, can you email me from a different ISP so i can respond to you?
I downloaded it right before I posted here. I can't do screen sharing. Give me your email address and I'll email you from google or something.dave wrote:i make new releases sometimes every day. i just made one this morning. when did you download it? release notes are on this page.
update: Emailed you from gmail...
why do you say you can't do screen sharing?
<silly>do you work for like the NSA and you have super secret stuff on your screen?
</silly>
Didn't need to try that as I already had those files installed.dave wrote:did you try this?
Your version 4 actually opened! Although it doesn't save most of the preferences. The 'add to library' only adds one file at a time. There's no way to fix the artists/titles of the songs because the tagging options in preferences don't work (most of it is missing).
Basically, there's nothing you can do except play one song which is just named with the filename...no good artist or title.
This still has a LONG way to go. Don't know if it's a Vista issue or what....
i think you're just not seeing what's actually there.
when you go add to library, pick a folder full of songs. select the folder and press "open" button and it will load the whole folder.
yes lots of the check boxes in the prefs aren't hooked up. i'm doing triage on them as we speak.
if your songs have meta tags, you can "advanced->special->pull meta data" on them and the info will go into the right columns
if not, you can "reinterpret names" to get the data in the right columns, you can do both in batches.
http://karaoke.kjams.com/wiki/Reinterpret
what may seem like a "long way" is only less than a month's work. there is in fact enough working now for you to get real work done.
perhaps you didn't see this on the downloads page:
Update: new version is out which fixes some bugs
just because you don't understand how it works doesn't mean it doesn't work, please take the time to understand and please don't just be a nay-sayer.The windows version is "for testing only", do not expect that it will work as awesome as the mac right now, this is the first time i've had it available for outside testing. Please ONLY try it if you're willing to help me debug the problemsBe sure to read up on what is still left to do!
