Audio lags behind video....
momswhorock
Post by momswhorock »
I am using K-jams on a 2008 2 GHz Intel Core 2 Duo macbook with 4GB memory and 500G hard drive. Often when I run K-jams, the audio starts to lag behind the video like it is taking too long to process it, and the graphics will not be synced to the audio. Is there something you can recommend to correct this, or is it just that I am not using a powerful enough computer to run the program?
Scott Parr
Re: Audio lags behind video....
Post by Scott Parr »
There is a feature in kJams called "Slipping". Here is a link to the explanation :-)
http://karaoke.kjams.com/wiki/Slipping
It allows you to "sync" the audio with the video. You can "slip" the video forward or backwards in increments of 1/10th of a second. It will remember this for that particular song.
If all songs are off, there is a "Global Slipping" to adjust all songs in your library.
It's pretty cool. Have Fun :-)
- Scott
