Update
djdave
Update
Post by djdave »
Hi Dave,
Every things been working great until today. I started kjams while online and was told to update. I did, and now I'm asked for permissions settings. when I try to print the instructions,Firefox crashes. Also,I get a kjams notice that my FlipforMac needs to be uninstalled,or undated. I downloaded the update, and still get the notice. I went to applications, and moved FlipforMac to the trash,(I think this uninstalls) and still no luck.
Please help, Thanks
djdave
Re: Update
Post by djdave »
Hi again, I went back to my original version,1.0d50r56. and it still works. Do I need the update?
Re: Update
if you're running shows and can't wait for my help, then go with what works. otherwise, i would really appreciate it if you would update to latest and let me actually fix the problems, because yes, you very definitely need the update. I simply can not and do not support older versions of kJams.
to fix your permissions:
http://karaoke.kjams.com/wiki/Permissions
to fix Flip4Mac, just download their latest updater and run it, i swear it will work. and no, deleting the application does NOT uninstall the plugin that kJams will continue to try to load.
if you still have trouble, please contact me on ichat and i will personally fix this for you
djdave
Re: Update
Post by djdave »
Hello again,
When I open ichat, I'm told that I'm unexpectedly disconnected from kjams. I don't have a .mac or mobileme account, and AOL hooked me up to an AIM account. Will the AIM work, or is there something I need to do to get ichat to work?
Thank you
Re: Update
you can use your AIM account with iChat. pleae ping me i'm on now
djdave
Re: Update
Post by djdave »
Once again, thanks Dave!
Re: Update
