Create a playlist of songs to purchase
dizzidecazz
Post by dizzidecazz »
Hi,
It'd be nice if I could create a playlist of songs to be purchased so I can buy multiple songs at once having used the search features to find them in the store. a check box in the store lists could serve the same purpose. It also be good for putting together a request list offline for those using it at venues without internet access.
that's my two cents.
damien.
Re: Create a playlist of songs to purchase
i'll add that to the list, thanks
