Hi
I have purchased the lite version of your software. Do I need to upgrade to the pro version in order to have dual screen operation, ie. search and playlists showing on my macbook, while CDG video graphics showing on external monitor? At the moment i can only use it in mirror mode.
Many thanks
Dual Screen
Re: Dual Screen
well, turn off mirroring in the displays prefs, and it will work.
Re: Dual Screen
This isn't working.
Is it not working because I have an evaluation version of the software?
I
I
Re: Dual Screen
this has nothing at all to do with kJams. this is a macintosh issue. go to apple->system prefs->displays->arrangement and turn off mirroring.
also you must have seen this from the downloads page regarding the limitations of the tryout version:
http://karaoke.kjams.com/wiki/Downloads#Limitations
to wit:
to wit:
There are no other limitations. If something goes wrong in the tryout version, do NOT assume that making the purchase will "fix" it or otherwise make it work, it is either a bug or a misunderstanding
