kJams CDG burn failure
franks
Post by franks »
Hope you can help.
I created several CDG's with kJams Producer all of which play back as created on the video screen.
Then I moved one CDG song to an empty playlist folder and executed a burn.
Burn was to a Plextor 840u unit using a CD-RW disk.
Repeated single burn for each CDG.
However, several songs did not burn, only the audio came thru.
Am I overlooking something?
Any insight would be appreciated.
Re: kJams CDG burn failure
in Producer, did you turn off "high quality render" to check how it will play from CD?
be sure to do that first. if they're missing graphics there, then the burned disc will also have missing graphics
franks
Post by franks »
Followed your instruction. Worked OK! Thanks again.
