I'm confused
DjFreakuency
I'm confused
Post by DjFreakuency »
Hey Dave, I just purchased kjams and can't seem to be able to work it... I'm not sure where it's supposed to show up and my playlist is empty after buying a couple of songs. I did get the confirmation from the songs purchases
Re: I'm confused
If you purchase songs from the kjams music stores, they will just show up in your library, if you purchase them elsewhere, place them all in one folder and use file/add to library within kjams.
Re: I'm confused
where what is supposed to show up?
and how did you buy the songs?
