Can't figure out which drive I can use
I have been searching the internet for hours trying to figure this out. I have a new MacBook Pro with a Matshita UJ-868 Superdrive. Can I use this to rip my CD-Gs into your software or do I need another drive. I found a Plextor 8X (610U for Mac) but the spec sheet doesn't list CD-G but a website I found said all Plextor drives read CD-G. What do you recommend?
Re: Can't figure out which drive I can use
1. Try ripping a CDG with the drive in your MacBook. It may work. I say this because my MacBook drive is not listed as one that works-except that it does.
2. If your drive does not work, then go here:
http://karaoke.kjams.com/wiki/Compatible_Drives
