Lyrics Decsync
Re: Lyrics Decsync
Sure, sure, just don't want him interrupting his show if he doesn't need to!
Wondering, might this relate to the extra debugging code thrown in to catch the *other bug?
way2fst4u
Re: Lyrics Decsync
Post by way2fst4u »
37 singers last night, and it was fine...didn't desync at all!
Scott
Re: Lyrics Decsync
not related to debug code. and: YAY!
Re: Lyrics Decsync
I'll be checking it tonight.
Re: Lyrics Decsync
I'm a home user so no interruption. I don't have a large rotation either so don't think that is a factor. I thought it was unrelated to kjams and caused by my computer resources, which is why I Didn't report it. Good to know the scrubber trick but I'll try sync slip next time.
Re: Lyrics Decsync
the thing i need most of all is a method to reproduce the problem. if i can't see it, i can't fix it.
Re: Lyrics Decsync
Sorry, Dave, didn't happen last night. But I DID crash three times, so you have some more crash data.
I will check again tonight.
Re: Lyrics Decsync
Re: Lyrics Decsync
Ok, so i know you need to know how to reproduce this. I can't figure it out. I can tell you it happened to me, i double clicked the song and the sync was off. I was able to correct it using Controls/sync slipping/ song slip back about 10 times until it was in sync.
As far as reproducing it??? I'll keep trying. :roll:
Re: Lyrics Decsync
Global no slip and song no slip were both checked.
Re: Lyrics Decsync
what if you set them both to zero?
Re: Lyrics Decsync
After i adjusted song slip, i did set them back to zero, it then became un-synced again.
Re: Lyrics Decsync
Then i hit stop and play and it was fine
Re: Lyrics Decsync
okay, if you can re-create this problem, on the fly, 100% of the time, please call me during office hours to show me
ostadler
Re: Lyrics Decsync
Post by ostadler »
Hi all,
I too have a desync bug. Every time I start kJams my lyrics are 1-2 seconds ahead of my music. Global sync is set to 0, I never changed anything here. When I then press REWIND and start from the beginning of the song it is ok. It lasts for a few songs, but as soon as I scroll through my library for a couple of minutes it seems to desync again. REWIND fixes it immediately.
Many greetings,
Oliver
