Weird issue with Numark DJ/IO and iTunes/kJams Crossfader
way2fst4u
Re: Weird issue with Numark DJ/IO and iTunes/kJams Crossfade
Post by way2fst4u »
DeusExMachina wrote:FWIW, this definitely sounds like an issue with the Numark driver, not kJams. I would submit a bug report to them.
Numark DJ/IO has no other problems with any other software. I've narrowed it down.
Scott
I don't doubt that at all. But I am pretty sure there is nothing in the script that should affect the sound channel, and if kJams is working fine without it AND works fine with it for a few times, I am fairly confident that it is an issue with the NuMark driver.
I suspect that it is getting confused by the volume changes, and somehow interpreting that as a loss of connection, or in some other way lossing its connection to the kJams stream.
way2fst4u
Post by way2fst4u »
DeusExMachina wrote:I don't doubt that at all. But I am pretty sure there is nothing in the script that should affect the sound channel, and if kJams is working fine without it AND works fine with it for a few times, I am fairly confident that it is an issue with the NuMark driver.
That sounds logical...it works fine with it on it's own...in any app.
When I couple it with the iTunes fader script is when I have probs.
Scott
You should contact them with specifics and see if they have any ideas or if they can figure out what the issue is.
Alternately, you can try the manual cross fader script. That might not trigger the same issue?
:o
