Stops respond playing video
Re: Stops respond playing video
dang.
well, i still can't reproduce the problem reliably.
if you can get a solid repro case, that will GREATLY help !!!!
It happens 100%, playing a mp4, interrupting it by starting another song hangs on repeat first seconds.
If i "stop" one first, then start another song it works!
If i "paus" and start another next one hang.
I ticked the setting "stop between tracks" and it works.
My guess it can't handle two mp4 simultaneously.
ps
added short logfile
starting song
pause (maybe pressed two times...)
start another
hang
kJams 2.log.zip
(6.42 KiB) Downloaded 918 times
edbronson
Post by edbronson »
Same problem, saving database every minute literally, then becomes unresponsive.
@edbronson are there other activities like pulling or pushing meta data? that would cause DB saves. and did you turn off "make backups" ?
