Compatibility list
sadly, it does not.
it's non-trivial to "support deinterleaving". and what a strange term that is. technically it means "support re-interleaving". basically what i'd need to do is interleave the graphics and audio (not too hard), introduce RS error correction (trivial), and introduce timecode (between trivial and not too hard) and figure out how to get the DiscBurningFramework to shove the raw data onto the disc (hard).
so, due to "hard", it's a huge amount of work for me, for a vanishingly small set of customers. I'd recommend you get a LightScribe for like $99 at amazon or something, and sidestep the issue all together.
Okay, i am looking for a drive that will do it, i just dont want to make the mistake of buying the wrong one again. Is there a particular model Light Scribe you reccomend?
thank you
Any LightScribe will work.
This is all i've got:
http://www.kjams.com/wiki/Compatible_Drives
