Crossfading from kJams Pro to iTunes (and Back)
I just upgraded to pro and loving it. I downloaded the crossfade icon onto my desktop. Do i need to click on the icon to change between kjams and itunes each time? Is there another way of doing this like a keyboard shortcut?
Thank you
Can someone jump in here? i've never used it.
jfbiii
Post by jfbiii »
You can install it in your scripts menu (the scroll icon on the right side of your menu bar next to the monitor, sound, clock, and your user name) and select it from there or, you can add it to your dock. I put it directly in between the iTunes icon and the kJams icon.
Just click it in the dock or select it from the script menu, and it takes care of everything else.
Okay, i put it on my dock. Thanks for the help
