Key Changer plugin
Re: Key Changer plugin
okay it's all done. send me an email and we'll set you up with a rogue build so you can test it
Dave, does this mean you are switching from using the AU plug in, or just that you fixed the aforementioned bug?
Also, if you are switching plug-ins, will this be canonical, or will there be a preference to chose? Just curious.
no, this "Wave SoundShifter" plugin *is* an AudioUnit plugin, only on the mac. it will be used if it's available, otherwise the built in AUTimePitch is used. There is a secret pref to turn it off however, "Use Wave SoundShifter for key changes (no tempo changing)"
Thought I had typed "the current AU plugin", but cool, that answers my question.
So the new plugin is used by default.
DaveT
Post by DaveT »
Hi Dave -- so far so good, its sounding very very smooth through headphones, i will have the full PA setup on Saturday where it will show its true colours lol. Many thanks for this help, it really is truly appreciated. Later today, I'm gonna set up my two MacBooks side by side with an older version of KJams on one and the new on the other to compare through my studio monitors. Must admit, the one song that really showed the artefacts was alone by heart, and i have just transposed it down 6 where even the best of plugins would have made some noticeable rumbles, but i can't hear anything so far through my headphones :)
thanks again for all your help
Dave (T)
yay!
rd93140
Post by rd93140 »
I have been experiencing the same issue, also on OSX (El Capitan).
Been a long time paid user of the pro version.
Has it been included in the latest official build?
Thanks,
Eric
are you using the latest kJams? that should sound better.
the next update (not current) should have it.
rd93140
Post by rd93140 »
You're right Dave, I just reinstalled 1.0.1b86 and it does sound much better :D
Can't wait for the next version.
Thanks Dave.
Eric
DaveT
Post by DaveT »
The difference is night and day. i have been checking just in my studio at the moment to compare, but the new plugin is miles better than the existing one. Got a 5 hour gig on sunday so will comment back when i see how it sounds through the big PA.
Dave
DaveT
Post by DaveT »
Sorry Dave --- meant to get back sooner -- what a difference, even my singer complimented on the difference in the sound through the PA (so it must be good lol)
Thanks agin for your help
Dave
DaveT
Post by DaveT »
Hi Dave i see from the latest release (1.0.2b8)
the "WAVE SoundShifter" plugin use defaults to OFF not ON, cuz it confuses people
I checked my preferences and see that both Au and sounshifter are set to True
<key>Use Apple AUTimePitch for pitch bending</key>
<true/>
<key>Use Wave SoundShifter for key changes (no tempo changing)</key>
<true/>
How can i guarantee my system is set to use the sound shifter one rather than AU?
Thanks again
Dave (T)
SoundShifter overrides AU, so if it's present and turned ON, it will be used.
you can see if it will be used if you hold OPTION while you go to prefs, then you'll see a "secret" pref panel with that option
DaveT
Post by DaveT »
Cool Dave -- thanks once again -- got it
Dave (T)
:D
