Location-specific load times
Re: Location-specific load times
i think load times on the order of seconds is "doing pretty good"
it's when it gets on the order of minutes that we have to take a hard look and find out what's the holdup!
As to issues with specific singers, that is certainly possible, For instance, my own personal history list will not load at all over server on the client machines (but works just fine on iOS). Others have also experienced this.
Load times still in minutes on other machine (4x i7, 8GB)
okay get r6 from here, it's the zip file one
Okay, so, there is definitely a machine-specific difference. Load time on this machine is over 3 minutes for the same library folder, with significant stalls on certain singers.
kJams 2.log.zip
Had to zip to upload
(36.29 KiB) Downloaded 570 times
No issues on my main machine, an no singer specific issues, even with mine (though I still can't load my History list over server) but huge issues on my work machine.
Also a LOT of cruft in the log relating to files in the library (on both machines). Wondering if there is something that can be done about that, as well.
okay, go get r7, same place, which hides singers that load quick, only logs singers that load slow.
I will, but not sure it is singer-specific. So I'll run it a few times to see if that changes run-to-tun.
I don't think that is what it is doing. Looks like the log is still listing every singer, even those that take 0.00 seconds to load!
kJams 2.log.zip
(1.52 MiB) Downloaded 431 times
Another run FLEW through the launch!
kJams 2.log.zip
(34.48 KiB) Downloaded 472 times
Repeated. So you must have done something separate from adding logging code?
okay next time, please remember to cut the log to the LAST run, you're sending me ten zillion runs in each log, i just need the last one.
also: oops, yeah, i swear i fixed it to ignore quick loads, but i didn't. NOW i did. go get r8, and sorry for the hassle, but i really want to fix this!
I was clearing history in the log. Guess that is not changing what is sent.
Also, after reboot, it is back to being slow.
Getting r8 and retrying.
Very divergent load times!
Archive.zip
3 logs
(63.36 KiB) Downloaded 460 times
And another one!
kJams 2.log.zip
FAST after another relaunch
(7.12 KiB) Downloaded 491 times
Two more:
kJams 2.log.zip
two runs
(14.97 KiB) Downloaded 616 times
WIDELY divergent load times, from almost 4 minutes down to under 8 seconds!
