Quicktime Export Quality
acemc
Re: Quicktime Export Quality
Post by acemc »
Hi Dave.
Sorry for the late response. I noticed 2 updates since I was here last (Damn, you've been busy!)
So I tested the HD output and it's amazing quality! Exactly the same as when played through Kjams.
Thank you for sorting this out so promptly :)
Unfortunately, I have to ask: Is it normal for it to take between 20-30mins per export?
I understand that HD would take longer to export than the normal SD, but this seems a bit too long.
Any resolution from 640X480 & up takes ages to export. It actually takes about 20secs just to open before exporting even starts.
Looking at cpu usage, my mac is hardly breaking a sweat. It's sitting at about 25% while exporting.
Am I doing something wrong? Is there any way to speed up the process?
Thanks for all your help.
hmm, let me look into that, it should be maxing at least one core during export
acemc
Post by acemc »
Any news on this one Dave?
Is the HD export super slow for you too?
i'm very backed up on bugs right now, but this is on the short list to investigate. i will post here when i have more info.
