Removing unused templates
Sedge
Post by Sedge »
Any way I can remove (or at least hide) my unused templates? I tried just deleting them, but they come back! Ideally, I'd just like to hide them, so I can bring them back easy if I need to copy an element from them. Of course, this applies only to the templates that are prepackaged with kJams - my own custom templates do not resurrect.
>>Sedge
Sedge
Re: Removing unused templates
Post by Sedge »
Small update to this - using a tilde in front of the filename doesn't work, as (I assume) kJams looks for the intact filename on startup. Tried it anyway, just in case.
i'll add tilde-hiding as a feature, it should work like that for all files.
Sedge
Post by Sedge »
Well, not sure this is working perfect, but I've got it to work. I first tried just adding tildes, but kJams still made new copies of the files. Then changed secret pref to not add files, and things worked out ok. I think in a perfect world, I shouldn't have had to change the secret pref, just adding the tilde should have enough to not re-add those files.
Still, end result is achieved. Thanks for this update, Dave!
good point! fixed.
