Power Karaoke and MTU Karaoke
I currently use Micro Technology (MTU ) and also have Power Karaoke for windows. I have the converter to i pod for karaoke. I am going to get a new Apple Mac for Fathers day (A surprise that I found out about ) Will your product be able to perform similar functions using my new MAC Book? Thanks for any info! Bill Berry svtbill@aol.com
yes, kJams will be able to load up all your MTU songs that are in Audio+G format or "exported for ipod" format.
kjams can also convert Audio+G to iPod video.
or, what exactly was your question?
if by "MTU Format" you mean "Audio+G" then yes, kJams will load and play them directly. However, if you mean ".kma" format, then they must be converted first. Here is the Conversion Tool.
