Hi Dave,
I recently upgrade to Kjams-2 and so far, so good. In my other MBP I installed the try-out vers. and I can see a short cut for "Messenger Message"-"Cmd+M" and Loop Messenger - "Cmd+L". I don't have those shortcuts in my Paid Verss. Is this normal?
Regards:
Krassi
ShortCut
Re: ShortCut
run kjams
go help->reveal prefs
quit kjams
in the folder that was revealed, throw out "keyboard.txt"
then run again
you'll have all the new shortcuts
quit kjams
then run again
Re: ShortCut
Thanks Dave,
Everything is OK. Later on I had to fix the Automator-Background, because of these changes.
Regards.
Regards.
Re: ShortCut
what is "Automator-Background" ?
Re: ShortCut
Please excuse my English. I mean Video Background. There is a script for it. So I had to change "Kjams pro" to "Kjams 2" .
Re: ShortCut
ah! okay
