Hi
I'm trying to play mpg files in kjams light. The import worked with no error. But if I want to play such a track I get the error
Can't move this media type to a background thread.
Can anyone help me on this ?
By the way : I got these mpg files by ripping a VCD with the open source tool vcdxrip.
Play mpg file in kjams light
good question!
Yes you caught me! MPEG1 and 2 files have what is called "muxed" audio, that is the audio stream is actually interleaved within the video stream (as opposed to keeping it in a separate stream). anyway long story short i'm working on it.
if you *really* want them to work now, you'll have to demux them before importing into kJams.
eventually kJams will do this for you, and also let you rip and play VCDs.
Thank you, it works now !
Thank you for the hint !
I've found a free MPEG to MOV converter on
http://www.squared5.com/
It works perfect and my wife is now happy with her Thai karaoke ...
Hi
I saw in your changelog that you fixed the 'background thread' problem and that you're now able to play MPEG-1 files.
How can I get this newest version 1.0d47 ? If I click on 'Check for updates', I got the answer :
You have kJams Light version 1.0d46.
no new versions available.
I wouldn't mind to be your 'tester' and I don't care if the newest version is still buggy. Thanks !
'twill be posted tonight
fear not, the new version shall be released tonight
need a lot more info than that
please email me your log file, thanks. to learn how to do that, check the faq
Still having trouble with MPEG
Hi, Just switched over to MAC and found this software. (Was using Tricerasoft...base version....not a KJ...just a home singer.)
Tried to play file and it said I needed the MPEG file. Followed the instructions from the site (download, move ffmpeg to library, correct folder) still says I need the download. Still using the tryout version of kjams so maybe that's it. Also, just put the kJams Pro application into the application folder...didn't run a download because I couldn't find a .dmg file. Maybe I missed something. Originally downloaded on a windows pc (save to file), unzipped on the windows pc, then moved everything over to mac.
Thanks for any help.
Russ
Russ
you need to download it on the mac. at the very least, transfer the zip file to the mac and unzip it there, do not unzip it on the PC
did you quit then run kJams after you installed the plugin?
More help with ffmpeg
Ok, I deleted what I brought over from pc and redownloaded fresh from the site. From the downloads folder, it must have automatically unzipped, because the kJams file with icon was the only thing there. I moved that to Applications. I had originally gone to Library, Application Support, and created a folder called kJams. I deleted the ffmpeg file I had placed there because I hadn't done it holding down the Option key, and I followed the directions again, this time holding that key down.
Tried it and no go, then restarted the program and no go. Any other ideas will be much appreciated. I love the design and setup of this program.
THANKS
Russ
THANKS
Russ
One more comment that might help with my ffmpeg problem....
One other thing I just tried...I looked up the file I was trying to play (Mack the Knife.mpg). I double clicked on it to see what would happen. It came up in a Quicktime window and plays just fine.
Thanks for any suggestions. Would rather is play in the player.
Russ
Russ
it should play just fine
please email me your fone number
