Can't get it to work
dparr05
Post by dparr05 »
I have a mac labtop with OX 3.4.9 I put KJams pro in my applications click on it and nothing happened also when I try to open a CDG with the open with KJams still nothing happens I am new to mac is there something I'm missing? Thanks for your time and effort.
Dustin
Re: Can't get it to work
Hello and welcome
In apps double click the app or better still drag it to your dock and then a single click will open it.
As for the CDG are you saying you have kjams open. If you do and you have the CDG on your HD simply add to library (file/add to library) then navigate to you tracks and hit enter. Then play the track within kJams
I'm going to guess you mean you have OS X 10.3.9
first let me say, upgrade to 10.5 if you're on PPC, or to the latest (10.6 currently) if you're on an Intel. kJams simply does not run on OS 10.3
once you do that, let me know and i can help with the rest
dparr05
Post by dparr05 »
So my I book G4 can't be upgraded any higher 10.3.9 is it is there any lower version that can work for me or another software?
you might try this version:
<no longer available>
but really, it's time to get a new mac. pretty recent intel notebook macs are cheap on ebay.
dparr05
Post by dparr05 »
So I am close it now act like it will open but the I get an unexpected error and it will not open
did you go thru the "completely delete esellerate" trick in the link?
if you still have trouble, get me on ichat.
RIFRAF
Post by RIFRAF »
Hi,
I'm, still having issues trying to purchase KJams Lite and Pro.
Keep getting "Purchase Result Error".
I've followed a ton of instructions and advice to address, including the removal of "EWS..." etc, but no luck.
Unfortunately I have a party tomorrow night and wanted KJams to be up and running for it:(
RifRaf
here's what i got on the subject
if you try all that and it's still teh failz, email me ASAP
Zombies: you have to shoot them in the head or they just come back to life!
:o
