Black screen on playback
EVO
Post by EVO »
Not sure if this is a bug but since it has happened a few times I figured I would pit it here and see if anyone else experiences the same problem.
Every once in a while, and I haven't been able to discern any patter or specific event that causes it, when I start a song instead of getting the video I just get a black screen. The music will play but the screen is black. This only happens maybe once or twice per show, and sometimes not at all. If I stop the song and start it again then the video will show up and things will go back to normal.
I am running Kjams 2 (latest version) on a MacBook Pro (Early 2011) with 16 GB of Memory
I am using Python to fade between Kjams and iTunes
Again not a huge deal as it doesn't happen often but I figured I would see if it is just me...
Re: Black screen on playback
i've never seen it
if you can get solid repro steps, that'd help nail it down.
here's more info on how to get good repro steps.
EVO
Post by EVO »
I will try to nail down a pattern but so far it seems random... :?
