A very recent finding, occasionally the CLUT seems to be incorrectly loaded. Like, just the low table, not the high, so the colors appear very dark, and the lyrics are barely visible. I thought this might be a bad encode, but later opening one such track in Producer, it was fine. Also, it has happened on tracks that I have done before, so I know they are good.
No steps.
CLUT loaded wrong (all colors darkened, screen almost black)
Last edited by DeusExMachina on Fri Jul 04, 2014 11:06 pm, edited 1 time in total.
Re: CLUT loaded wrong
generally, "no steps" means "there's nothing i can do, really".
and in that case, there's no need to report it.
the only *actionable* bugs are those that I can reproduce. If you want to see if i'm aware of a bug already, i think email is best
but thanks in any case!
I think we both know you would have said the same thing to me over e-mail.
I will try to find steps.
yes but thru email we're not clogging the forums with unanswered questions
In my defense, the thinking was, perhaps there were others experiencing the same issue who could provide additional info!
very well, fair enough. Anyone else ever see the same symptoms? (faded / darkened colors during playback) ?
Maybe I should reword the heading in more civilian friendly terms?
