python27.dll
TheWarrior97
python27.dll
Post by TheWarrior97 »
Says the file is missing and won't open the program. Reinstalled with the same issue using 1.09kjams
www2000
Re: python27.dll
Post by www2000 »
10 caused the error
History doesn't have 9, it appears to be 10.
Grabbed 8 and installed it, but still same python27.dll error.
Happened on Win8 Tablet and happened on Win7 HTPC.
The only fix (If you use this information to fix it yourself, you do so at your own risk!) I've been able to manage is grabbing the dll off dll-files.com
http://www.dll-files.com/python27.zip?0WJhT0XJeR
And enter it in the same directory as the kJams exe. Worked on both Win7 and 8
and I'm up and running.
Re: python27.dll
fixed! (also fixed ability to get b9)
go download and install the latest (b11) and it should all be fine.
