Search crash
Search crash
I've got the latest kJams and when I search kJams quits
If I search for one letter and let that search complete and then search for the next letter in the word that doesn't make it quit.
If I paste a word in the search that doesn't make in quit.
But if I type more that one letter one after the other kJams quits
Here's the crash report
Version: kJams Pro 1.0b07r00 (1.0)
Code Type: X86 (Native)
Date/Time: 2013-04-10 09:34:46.981 +0100
OS Version: Mac OS X 10.6.8 (10K549)
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 com.metamuse.kjams 0x0004051d CApp::Crash() + 3
1 com.metamuse.kjams 0x00231723 CCriticalRecList::CCriticalRecList(CSearchManager*, bool) + 111
2 com.metamuse.kjams 0x00231ae4 CSearchManager::erase(SuperString const&) + 36
3 com.metamuse.kjams 0x00231cf4 CSearchManager::CSearchRec::completion() + 56
4 com.metamuse.kjams 0x003e250e CSearchManager::completion(long, SuperString const&, SDB_Selection&) + 310
5 com.metamuse.kjams 0x0029427c CT_FilterSelection::completion(long) + 62
Re: Search crash
fixed. new build in a few minutes
Re: Search crash
Dave, i just sent crash report. Im having the same issue of quitting on search. I have version10b9
Re: Search crash
This happens on both my machines, appearently it works untill i type a number in the search bar. Ex. 1,000 faces or 500 miles
Re: Search crash
just did a minor overhaul of how search queries are tracked, fixing crashers.
please try the next release, let me know
Re: Search crash
Yeah, still having issues, i typed "1,000 and it yields appropriate results. If i just enter 1000 (minus the comma) it crashes(shuts down with no message.)
Re: Search crash
I did update to R10 before i tried this
Re: Search crash
send the crash report please :)
Re: Search crash
I'm not getting the usual crash report on this bug, it just quits, where can i find it? Is this what you need?
Process: kJams Pro [5203]
<snip>
Re: Search crash
sorry, i meant "by email", thanks.
and yes, that is part of it, but the missing critical piece is the log file.
please dig it out manually. if you just go help->send log file, that does NOT send the log from the crash.
Re: Search crash
if you're crashing on r10 or later when you search, please call me during office hours.
Re: Search crash
Sent via email. Is nobody else having this issue?
Re: Search crash
for the workaround: sort by PLI
the problem is your metadata is not getting properly cached, so when you're sorted by, say, "Album", and you do a search, some of the songs' album data gets loaded, causing it to need to re-sort by album, DURING the search. now, when you're searching a list, and someone scrambles the list when you're part way thru the search, it messes up your search. unfortunately, this causes kJams to crash.
the permanent fix would be to somehow get all your album data properly cached and saved.
