Thanks, Dave for the new Pre-Cache functionality!
Unfortunately, it's not working for me.
If I right-click a song in the Tricerasoft library, and press Pre Cache it does nothing.
If I select the rotation and select a song in the rotation that is streamed from Tricerasoft, and press Pre Cache, I get the following error:
"Assert Fail: pIP, in file: '/Users/davec/Developer/depot/kJams/Development/ source/Music/CSong.cpp' at line 4803"
(FYI: There's a space before the word "source" in the above pathname, just like I typed it.)
Ron
Pre-Cache not working, and gives error
Re: Pre-Cache not working, and gives error
the error there is that it is enabled at that time. you are NOT meant to play songs directly in the music store. drag said song to a singer or playlist, play it from there.If I right-click a song in the Tricerasoft library, and press Pre Cache it does nothing
oops! this has been fixed. get the rogueAssert Fail
Thanks Dave!
Could I suggest not having the right click menu item appear, or have it disabled, when it's not able to be used?
that's, um, what i already did.
Reading my mind again?
my sensors are omnidirectional
