Time column
Time column
I'm often asked if there's enough time left for a singer to sing a song they've put in to sing, I then work it out by adding together the duration of each song.
Is there a way for you to put an extra column in the rotation window that would have the time the tracks end, then we could see how many songs will be sung before the night ends
I know your busy at the moment but it's good to know you listen.
Re: Time column
yes that's actually on the list
