Formats Request
lince32
Formats Request
Post by lince32 »
I love your program but I'm still stuck with windows for most of the bases I have.
I have more than 6000 Bases in mp3, it's just an Mp3 file but if you play it with Qmidi you will see the text and the sincro will work wile Kjams just plays the music with no text.
I'm not sure the name of this special mp3 format but it works.
Other very diffused format is Karafun extension .kfn.
I think the think the first format should be the easiest to implement as I believe it just has lirics and sincro in the tags of the mp3.
Can i send some sample for your evaluation?
Thank you again for your amazing software!
Re: Formats Request
yes, please send me some samples of the first type. some of the second would be fine too.
lince32
Re: Formats Request
Post by lince32 »
where do I upload? is says I can't attach bigger files over 2mb
Re: Formats Request
just email them to me
lince32
Re: Formats Request
Post by lince32 »
I could not find your email on the site, sorry I must be dumb.
Re: Formats Request
fascinating! where did you look? what did you click on? please tell me cuz if you can't find my email address then i'm doing something wrong!
hint: did you see "kjams links->contact"?
but PLEASE tell me where you looked and what you tried FIRST!
lince32
Re: Formats Request
Post by lince32 »
I was looking on this forum site only, did not realized your contact would be on your website I tried to clid on your name on the forum but did not find an email there.
By the way I just sent you two email with the files let me know if you need anything else I have more examples if needed
Thank you for the help.
Re: Formats Request
do you see a different screen than i do here?
thanks for the files!
lince32
Re: Formats Request
Post by lince32 »
I see a different screen with no email, it's attached the screenshot
Re: Formats Request
Well I'll be! How about that! You are completely correct, sorry about that!
Try it now, i think i have fixed it!
lince32
Re: Formats Request
Post by lince32 »
Yes!! now it's fixed :-)
Re: Formats Request
