Problems with iJams and wtkJams on iOS 8
djunod
Post by djunod »
For some wonderful reason, I'm sure, Action Sheets (used to change tempo of a song in the Tonight list) aren't showing up properly on iOS 8. Hopefully there will be an update to wtkJams over the next couple of weeks to fix this issue, but until then, hold off on upgrading to iOS 8 on your devices that you use wtkJams on.
davina
Re: Problems with iJams and wtkJams on iOS 8
Post by davina »
awesome!
