Palm support?
Palm support?
I have a couple of palm zire 72s. Does anyone know what software, preferably free, i can use to transfer the kjams songlist to the hand helds? It seems there is no database on the palms.
SWLinPHX
Re: iJams
Post by SWLinPHX »
The database programs I was using (and still have) are HanDBase, SmartList To Go, FileMaker for Palm, etc. All work reasonably well, but I believe it has been a while since they have been supported or updated. I believe they all work by importing comma-separated or tab-delimited exports of songlists or any database you want.
MacBook Pro-15.4" [unibody] 2.53GHz-4GB: Mac OS X 10.5.7
also:
iMac G5-20"/2 GHz-2 GB: Mac OS X 10.4.11
iBook G4-12"/1.33 GHz-1.5 GB: Mac OS X 10.4.11
PowerMac G4 w/21" CRT Studio Display/500 MHz-1 GB: Mac OS X 10.3.9
Re: Palm support?
Smartlist to go is for windows, do they have a mac version? Handbase is a little expensive but i havent checked out filemaker pro yet, will research that one. Thanks for the help.
Online
Re: Palm support?
i'm not really familar with the whole palm thing
Re: Palm support?
Found documents to go, works great with palm.
Online
Re: Palm support?
