Hello. I am using the unregistered version of kJams Pro with the burning plugin on an emac. 1 Ghz PPC 512 MB SDRAM. The burner is an aftermarket PIONEER DVD-RW DVR-107D.
I successfully ripped two songs and was able to play with video on my computer. But when I burned it, no video showed in my karaoke. Is there something I didn't do properly? When I ripped, I simply dragged the songs from the CD list to the playlist. I created a new playlist of two songs and clicked burn. The burn reports a successful completion.
I am eager to purchase this app, so any help to get this to burn successfully would be appreciated.
Testing
burning
From the burning page:
http://www.kjams.com/wiki/Burning
also: i'm not sure it works to drag from a disc directly to a playlist. try drag it to the library, then from library to a playlist.
So it's a drive compatibility problem, sadly you need a new drive. Good news is they're pretty cheap (< $100)WARNING: Pioneer DVR drives do NOT seem to produce viable CD+G discs. They will play in computers but not on real hardware
Thanks anyway.
No Dice. When I got home, the burn failed. I guess I must wait until I buy my laptop. Thanks.
burning
keep in mind, there's no notebook / powerbook / ibook / macbook that i know of that has a CDG capable drive. So don't bother waiting, go get a new drive now You'll be glad you did Check the FAQ for my recommendation.
