Burning Multiple Karaoke Tracks From kJams On A Disc
Can you burn Multiple karaoke tracks on a disc? If so how many? How do you know what the file size limit is?
Re: Burning Multiple Karaoke Tracks From kJams On A Disc
of course. the tryout lets you burn 2 tracks, the unregistered lets you burn as many as will fit.
it's not a file size limit, it's a time limit. most CDRs limit you to 80 minutes or so.
check the status line at the bottom of the browser window when you're building your burn playlist, it will say how many minutes the disc will have used up. i think kjams won't even let you go over 90 minutes.
read up on burning: see step 6 on "how to use it"
http://karaoke.kjams.com/wiki/Burning
Awesome thanks, and can you burn disks if the files are in another format other than mp3? The tracks I have are in mp4 format.
kJams can burn any Audio+G track. that is, a CDG file and an audio track IN ANY FORMAT. wav, aif, m4a, mp3, even mp4 if it's only the audio.
it is physically impossible to create a CDG disc from a "movie" of any kind, they MUST be CDG files
