uninstalling lame
uninstalling lame
Hi, I was wondering how I could completely uninstall lame and all the files associated with it? Thanks
uninstall lame
do a search for "lame" and delete it all.
the installer that I made only installs these items:
/Library/Frameworks/LAME.framework
/Library/QuickTime/LAMEEncoder.component
Why would you want to un-install LAME? Are you having trouble? Are you trying to solve something?
If you've previously installed LAME from another source, it may have gone into your user folder, you should just search your entire hard drive.
