Changing Rhythm
weezer1000000
Changing Rhythm
Post by weezer1000000 »
I know how to change the pitch, but I don't know how to change the rhythm. I am reading the documentation and following the instructions.
When I press those keys I get adjusting the volume.
Re: Changing Rhythm
are you on mac or windows?
what documentation, exactly, are you following? (link)
what keys, exactly, are you pressing?
weezer1000000
Re: Changing Rhythm
The documentation is on your web site under documentation. The keys are the squiggly symbol command with arrow pointed up.
I am Mac.
Re: Changing Rhythm
You are very silly. I'm well aware of where the documentation is, since I put it there, ;). I'm asking you for the actual link to the page that has incorrect info.
The page that I know of is this:
https://karaoke.kjams.com/wiki/Pitch_and_Tempo
Which correctly documents the keys.
However, I see it has only mac keys
On windows, the cloverleaf is control, the hollow up arrow is shift (not the up arrow key) so I see where your confusion was.
weezer1000000
Re: Changing Rhythm
That is the web site I'm using. When I press those keys I don't get the rhythm. Obviously I'm not reading it correctly. What am I doing wrong?
Re: Changing Rhythm
To be explicit: On windows it is:
Control-shift-"[" and "]"
weezer1000000
Re: Changing Rhythm
Sorry for the confusion. I am Mac.
Re: Changing Rhythm
Then use command-shift-"[" & "]"
weezer1000000
Re: Changing Rhythm
Thank you so much! This is such a great program!
Re: Changing Rhythm
