Regular Singer missing...
Re: Regular Singer missing...
noted: but that isn't this problem, cuz that won't cause a duplicate ID
No, but what is does do is take up that name, so that when the person tries to re-add their name, they get a 1 after it, just as described, even though from within kJams, you can't see a singer with that name, and so can't figure out why the 1 gets added.
okay similar symptom, i see. but definitely a completely different bug
Dave, I don't think it is. If you look at his original post, it matches 100% of his symptoms. I think the duplicate ID issue IS a separate issue, but that was a separate issue I was having not him!
way2fst4u
Post by way2fst4u »
My original singers were not ever deleted.
Scott
Check to see if the alias is actually still connected to the original file.
way2fst4u
Post by way2fst4u »
It did it again last night! WITH MY Profile. Actually deleted it. I found it in the trash! I DID NOT delete anything. When I clicked on my name, it showed all dashes...no music. I freaked a little. dragged it to the desktop and then back where it belonged. Something is wrong somewhere. Either with kJams or with the Singer copy script...it's SO RANDOM though...?
Scott
i can't help with the "Singer Copy" script, sorry.
if you can figure out how to make it happen, or if you see it happening every time you start, please call me during office hours!
