The Charbuster Buzz
simpmech
The Charbuster Buzz
Post by simpmech »
With the news of charbuster closing shop & the new http://www.digitraxkaraoke.com taking over its music I am wondering where we go from here. Specifically in the streaming of music and the digital world (it's said digitrax will not be producing CD+G's, only digital format). If so, I wonder if it will be the digital cards like CB was going to, and if so, will kjams integrate these into the library with ease like ripping a disc? (it may already, but I was disc based so I never owned a card)
Just putting thoughts to "paper" here
Derek
Re: The Charbuster Buzz
the streaming / download store built into kJams will likely transition smoothly, and hopefully without interruption. probably the only difference you'll see is the name will change, an it will get a new icon.
when you purchase digital files on a USB stick, yes, presuming they don't do something dumb with DRM, you'll be able to "rip" them into kJams just fine too.
simpmech
Post by simpmech »
:D
