Transferring music from mac to PC
Re: Transferring music from mac to PC
Don't forget, you can use BatCHMod to do the whole Music folder, which should fix things. Also, you can copy the backup to your main drive, which should also fix all the file permissions, though it might be a tedious process, as OSX repeatedly asks you for your login credentials.
