I have a webspace... Can I install kJams Server on this server? How do I do that?
Leo
Search songs without kjams server
Re: Search songs without kjams server
what does that mean "i have a webspace" ?
if you have a server that IS a mac, then yes, you can run kJams on it, and it will serve up the list.
sorry.
no, it's a linux server... No chance?
kJams doesn't run on Linux, not without some mac emulator.
I suspect that it would all depend on what you wanted to do with it. If you wanted to use the actual kJams Server, let users log in, select songs, all that, then you are SOL on anything other than OSX.
If you just want people to be able to search your database, then you can write a simple webserver on Linux that will accomplish that, after exporting your library as CSV.
what he said.
