time searching for songs?
Re: time searching for songs?
No update on SQL, it's on the back burner until i complete the Windows version.
As someone who IS testing it, I can tell you that it in general works OK. Mostly just undesirable assert fails that you can click through. I sometimes keep a copy of SilverJuke or some other karaoke program running in the background, to fill in if kJams crashes. All that said, since SQL is now officially backburnered, I do not use it live as much, since there is less point to testing it, being that the bug reports get filed for later, anyway.
- Jon Leggitt
Sorry about bumping the thread again, but I'm curious if *any* progress has been made on the SQL front.
I hate to harp on it, but search times are the only glaring issue left, IMHO, in what is otherwise an absolutely stellar app.
Got to agree thereJon Leggitt wrote:search times are the only glaring issue left, IMHO, in what is otherwise an absolutely stellar app.
That and it doesn't mix drinks!
- Jon Leggitt
Ummm... Did anyone besides me notice that the question wasn't actually answered?
Oh, and it doesn't need to mix drinks - I host in pubs.
It WAS answered:
yeah the only way that's going to get done sooner is if some enterprising code guru wants to step forward and write some SQLite code.
It's very discouraging to see that well over a year and a half later there is no progress made on the search times.
this is a great program but it is essentially useless to me until the search times are dramatically reduced. I can not afford to wait over 2 minutes for the initial search to finish.... the entire program locks up until it's done.
after the initial search the times are much less...but still in the 6-7 second range..and thats just an eternity during a live gig. it should be almost instant, and ideally it should automatically trim the visible songs in the library as you type.
I wonder if there are sql forums where you could post for hired jobs... this could be a nights work for some sql whiz kid and maybe not all that expensive to get accomplished.
It should not be taking that long to perform the initial search. It sounds like there are some other issues involved.
That said, unfortunately the old search code was worked in at such a low level that the extrication of the old search code and installing of new SQL is far from trivial and much more complicated than a nights work.
Yes, i'd love to get that going, but i am just not versed in SQLite. I tried. I tried real hard. I actually worked for 6 months on it. yes, i did. but it just kicked my ass, and meanwhile, kJams stagnated. That's why it's now on the back burner. I am finishing the Windows version and the "1.0 Golden Master", so i can call it "done".
It does sound to me like you've got something extra slow going on, like you're showing a slow sort column. There are things you can do to speed up searching, please try them.
Fast searching and cross-fade filler music are the top two things i'm going to do for v1.5.
Meanwhile, if you know any SQLite code guru's who want to help, let me know.
I've worked with SQLite on Android, and now in .NET (MonoTouch & MonoMac) for wtkJams. Back when we were messing with Search *, I was downloading the entire kJams pList database and inserting into a SQLite database. I've thought about doing a MonoMac app that would run on the laptop/puter running kJams that would download the full song list and construct a SQLite database to send to wtkJams (it's a lot smaller then the pList due to never repeating an Artist name or Song Title, etc).
if you're stoked, you can help me get the SQLite db just going in kjams. interested? note: it's a lot of work.
Posting here to follow progress...fast search and filler music would make this app pretty freaking perfect! Now that I am getting used to it...I'm impressed with what it can do!
Scott
Scott
Filler music as a feature is not really necessary. Just use the crossfader script from here:
https://karaoke.kjams.com/wiki/Code/new ... Crossfader
