ShowScreen Meta Tags Temp
Jump to navigation
Jump to search
You can use meta tags in a Rotation ShowScreen to show meta data for each song and singer. Here is a list of supported tags. To use them, place them inside of square brackets. For example, to show the current singer, you type [SNGR], and to show the current singer's song, you type [name]. To see an example of this, simply edit the Rotation ShowScreen.
There are special tags you can use as well. Some only work in a Rotation ShowScreen, some only in Showscreen Message, and others in any ShowScreen.
- [+sgr] - increments the "current" singer to the next one, so the next set of tags will come from the next singer and the song associated with them
- [msg ] - show whatever message is currently saved as the ShowScreen Message
- [venu] - the current venue name
- [eCrT] - how long until, and the exact time of, the "end of the current rotation"
- [eArT] - how long until, and the exact time of, the "end of all rotations"
