Ripping from Other Formats Temp
davequestion: didn't do any editing on info below, 'cause I have no idea what you're talking about!
To rip from a DVD, use HandBrake.
To rip from LaserDisc, you'll need some kind of A to D encoding hardware, like an EyeTV: USA, Europe.
The above rippers produce QuickTime compatible MPEG files, which you can simply import into kJams with File → Add to Library.
To rip from a SuperCDG or a NEO+G, just stick it in, select the songs you want and go to File → Rip Selected or just drag them to the Library.
To rip from VCD: First you must manually enter meta data for all the tracks you want to rip. Then, select the tracks you want and drag them to the Library icon.
