How long until I have to pay again
From KJams Wiki
Quick Answer: a long, long time.
Specifically, i'm in "development" stage right now, and I'll be there for probably another year, or more, it is difficult to tell (As of Feb 2009)
then comes alpha stage: that can be a year or more, maybe a LOT more.
then comes beta, which is probably less than 6 months
then RC, which is less than a month probably
then is 1.0 "golden master"
then AFTER that, is "the dot releases" which would be "1.0.1", "1.0.2" etc
you will get ALL that for free with the license you buy now.
The only time I will charge you again is for a "2.0" release. And I even feel bad about that, but if I didn't charge, I wouldn't be able to write "2.0" in the first place, so you have to want it.
