Also, I said, there really should be a way to have singers enter a last name or initial, since otherwise you end up with lots of John 1-John13s and lots of other biblical references in your venue list.
Great idea, says Dave, blah blah Windows, blah blah on the list, blah blah version 1.0. (Sorry dave )
So I took matters into my own hands!
So now, without further ado, here is a working substitute for the two files in server. Just place them in:
/Applications/kJams Pro.app/Contents/Resources/server
Don't know how to get there? Then don't do it! I am not providing further instructions for a reason!!
Replacement for mainscreen.html:
<html>
<head>
<title>kJams Server</title>
<script src="spry/xpath.js"></script>
<script src="spry/SpryData.js"></script>
<script src="ui.js"></script>
<script src="data.js"></script>
<script src="main.js"></script>
<script src="common.js"></script>
<script type="text/javascript">
var timer = 0;
function set_interval() {
//the interval 'timer' is set as soon as the page loads
timer=setInterval("auto_logout()",120000);
// the figure '120000' above indicates how many milliseconds the timer be set to.
//Eg: to set it to 2 mins, calculate 2min= 2x60=120 sec = 120,000 millisec. So set it to 120000
function reset_interval() {
//resets the timer. The timer is reset on each of the below events:
// 1. mousemove 2. mouseclick 3. key press 4. scroliing
//first step: clear the existing timer
if (timer != 0) {
clearInterval(timer);
timer = 0;
//second step: implement the timer again
//completed the reset of the timer
function auto_logout() {
//this function will redirect the user to the logout script
window.location=logoutlink;
</script>
<style type="text/css">
#main {
padding: 10px;
margin-right: 20px;
margin-left: 20px;
border-style: solid;
border-color: #000000;
border-width: 1px;
background: url('metal.jpg');
cursor: default;
#title {
padding-right: 30px;
text-align: left;
font-family: Arial Black;
font-size: 24pt;
font-weight: bold;
margin-bottom: 5px;
#search {
width: 100%;
text-align: center;
#searchfield {
height: 21px;
width: 144px;
background: url('search.png');
border-width: 0px;
padding-left: 7px;
padding-right: 7px;
padding-top: 2px;
#left {
float: left;
width: 200px;
margin: 10px;
margin-left: 0px;
#status {
text-align: center;
color: #333333;
padding: 0px;
margin: 0px;
#playlists .KJList {
overflow: auto;
height: 240px;
padding: 0px;
background-color: #FFFFFF;
border-color: #999999;
border-width: 1px;
padding: 0px;
#playlists .KJList td {
padding: 0px;
margin: 0px;
#playlists .KJList table {
margin: 0px;
padding: 0px;
#photo {
padding: 3px;
width: 190px;
height: 143px;
max-height: 150px;
overflow: hidden;
margin-top: 5px;
border-width: 1px;
#songs {
border-width: 1px;
margin-left: 220px;
min-height: 400px;
#message, #waiting, #msg_dosearch, #msg_error {
text-align: center;
font-size: 14pt;
#songs .KJList {
padding: 0px;
height: 400px;
overflow: auto;
.KJListColumn {
padding: 0px;
margin: 0px;
background: url('column-bg.jpg');
cursor: default;
.KJListColumn td {
border-width: 0px;
border-right-width: 1px;
.KJListColumn .primary {
background: url('column-selected-bg.jpg');
.KJListItem, .KJListItem_alt, .KJListItem_selected, .KJListItem_drag, .KJListItem_target, .KJListItem_alt_target {
padding: 0px;
padding-top: 0px;
padding-bottom: 0px;
margin: 0px;
cursor: default;
border-color: #FFFFFF;
border-width: 0px;
border-bottom-width: 1px;
.KJListItem_alt {
background-color: #EEEEFF;
.KJListItem_selected {
background-color: #4444FF;
color: #FFFFFF;
border-width: 0px;
border-top-width: 1px;
.KJListItem_drag {
position: absolute;
border-width: 1px;
background-color: #DDDDDD;
filter:alpha(opacity=40); /* for IE */
-moz-opacity:0.4;
opacity: 0.4;
.KJList input {
padding: 0px;
margin: 0px;
border-width: 1px;
.KJList input:active {
background-color: #000000;
color: #FFFFFF;
#playlists .KJListItem, #playlists .KJListItem_alt, #playlists .KJListItem_selected, #playlists .KJListItem_target, #playlists .KJListItem_alt_target {
background: url('playlist-icon.gif');
background-repeat: no-repeat;
padding: 0px;
padding-left: 20px;
border-width: 3px;
#playlists .KJListItem_alt {
#playlists .KJListItem_selected {
color: #FFFFFF;
background-color: #9999FF;
.clear {
clear: both;
</style>
</head>
<body onLoad="set_interval()" onmousemove="reset_interval()" onclick="reset_interval()" onkeypress="reset_interval()" onscroll="reset_interval()">
<div id="main">
<table><tr><td id="title"><nobr>Singer: {singer}</nobr></td><td id="search"><nobr>Search Library: <input type="search" id="searchfield" name="search" onkeypress=searchKeyPressed(event) /> <input type="submit" style="" name="dosearch" value="Go" onclick=m_doSearch() /></nobr></td><td id="help"><nobr>[ <a id="helplink" href="">Help</a> ] [ <a id="logoutlink" href="">Logout</a> ]</nobr></td></tr></table>
<div>
<div id="left">
<div id="playlists"></div>
<div id="photo"><img src="kjams-main.jpg" /></div>
</div>
<div id="songs"><p id="msg_error"></p><p id="msg_dosearch">Please enter a serach.</p><p id="message">No Playlist Selected.</p><p id="waiting">Please wait, loading playlist...</p></div>
<div class="clear"> </div>
<div id="status">Welcome to kJams!</div>
</div>
</div>
<script language="javascript">
//Bind key press function
document.onkeyup = m_keyPressed;
//Hide message fields
document.getElementById("waiting").style.display = 'none';
document.getElementById("msg_dosearch").style.display = 'none';
document.getElementById("msg_error").style.display = 'none';
//Plug in help and logout URLs
document.getElementById("helplink").href = url_help;
document.getElementById("logoutlink").href = url_login;
//Playlists
m_populatePlaylists();
if (0) {
//Song list
var songs = new KJList();
songs.create(document.getElementById("songs"));
songs.setColumns(Array("#", "Song Name", "Artist", "Pitch", "Add to", "Add to"), 1);
//Set clipping
songs.setClipping({'right' : songs.getColumnWidth(5) + songs.getColumnWidth(4) + songs.getColumnWidth(3)});
getSongs(url_songs, populateList, 'playlist=1');
function populateList(songList) {
for(var i = 0; i < songList.length; i++) {
songs.addItem(songList[i]['number'], Array(songList[i]['number'], songList[i]['name'], songList[i]['artist'], "<select><option>+6</option><option>+5</option><option>+4</option><option>+3</option><option>+2</option><option>+1</option><option selected>0</option><option>-1</option><option>-2</option><option>-3</option><option>-4</option><option>-5</option></select>", "<input type=\"submit\" value=\"Tonight\" />", "<input type=\"submit\" value=\"Favorites\" />"), null, null, false);
songs.color();
</script>
</body>
</html>
<html>
<head>
<meta http-equiv=Content-Type content="text/html; charset=UTF-8">
<title>kJams New Singer</title>
<script src="./spry/xpath.js"></script>
<script src="./spry/SpryData.js"></script>
function catname(){
var firstname = document.forms[0].singerfirstname.value;
var lastname = document.forms[0].singerlastname.value;
document.forms[0].singername.value = firstname + " " + lastname;
function validate(thisform) {
with (thisform){
if (singerfirstname.value=='') {
alert('Hey, unless you\’re Obama, ya gotta give me a first name too. Try again.');
event.returnValue=false;
else if (singerlastname.value=='') {
alert('What, you think you\’re Madonna? A last name is required. Lets try this again..');
</script>
#main {
width: 400px;
margin-left: auto;
margin-right: auto;
text-align: center;
border-width: 1px;
#main p {
font-size: 24pt;
#main table {
margin-left: auto;
margin-right: auto;
#main img {
margin-bottom: 10px;
</style>
</head>
<body>
<div id="main">
<p>New Singer</p>
<img src="kjams.png" /><br />
<font color="#FF0000"></font>
<form id="form" method="POST" action="" onsubmit="validate(this);">
<table>
<tr><td>First Name: </td><td><input type="text" name="singerfirstname" value="" onkeyup="catname()"/></td></tr>
<tr><td>Last Name: </td><td><input type="text" name="singerlastname" value="or last initial" onfocus="this.value= (this.value=='or last initial') ? '' : this.value" onBlur="this.value= (this.value=='') ? 'or last initial' : this.value" onkeyup="catname()"/></td></tr>
<tr><td>Password: </td><td><input type="password" name="password" value="" /></td></tr>
<tr><td>Again: </td><td><input type="password" name="confirm" value="" /></td></tr>
<input type="hidden" id="singername" name="singername">
<tr><th colspan="2"><input type="submit" name="submit" value="Jam Out!" /></th></tr>
</table>
</form>
<p style="font-size: 12pt;">[ <a href="/">Back</a> ]</p>
</div>
document.getElementById("form").action = url_newsinger;
</script>
</body>
</html>
