Singing to myself
Singing to myself
I don't have the money right now - but someday I'd like to be able to practice singing in my room and have the singing sounding like I was connected up to the Karaoke equipment. I see that there are some pretty cheap microphones that have reverb and plug into my Mac's USB port. But I have also read that I can't use kJams and a microphone and have the sounds come out together using my internal Mac's speakers. (I do have some nice external speakers - but they are in the other room using an AirPort to play from my Mac's iTunes (and kJams). I also have headphones.
Once per month I take my Mac downstairs for Karaoke night, where we have microphones hooked up to the Karaoke machine that my senior living apartments own.
Does anybody here have experience in setting up a cheap setup that is suitable for practice without setting up the whole Karaoke setup?
Thanks.
Re: Singing to myself
you CAN hook a mic directly to the mac, but you'll get "latency", ie: you'll hear your voice just slightly delayed which may drive you nuts (it drives me nuts making it impossible for me to sing or have fun). Some people actually don't mind it, it's just a very shallow echo. So you can try it. more info here.
So you recommend getting the cheapest kind of mixer between my Mac and using external speakers?
I've Googled lots of recommendations to *reduce* latency. Lots of these are for people who want to *record* in apps like Garage Band. I don't need recordings beyond checking to see what I really sound like (my phone could record that).
I've seen some mixers real cheap mixers and microphones - but don't know how to evaluate if they are *too* cheap. I do want enough reverb to find out what I sound like when connected to the Karaoke machine.
Here's a link that I found with real cheap examples: https://www.guitarcenter.com/Behringer/ ... adType^PLA
Or here's a cheap "Karaoke mixer": https://www.amazon.com/Karaoke-Mixer-Fi ... ech080a-20. It even offers a very cheap microphone to bring up the combination cost to less than $40. Of course, I could also spend a thousand, should my wife win the lottery. I could get the cheapest without saving - but don't want to waste my money if it won't be adequate.
Is the cheapest likely to be sufficient for my wants? What minimum criteria should I look at?
Both those units are sufficient. If you want a better mic, you might consider Craigslist.
Thanks.
