David,
In KJAMS, you have the SERVER tab. In the server tab, you have the check box to disable enable server, search result value and time out limit. Once, the check mark is removed, disabling the server, guest loose all communication to KJAMS which is obvious, but at the same time, they are not able to see the rotation or look at the songs they have selected.
My feature request is:
Can you code a button that instead of disabling the server, prevent any new songs from been submitted. This will allow the user use of the app still with out being able to add new songs.
Don't turnoff the server - we need to work
Re: Don't turnoff the server - we need to work
yes, that request is very high on the "to do list", thanks!
Awesome can't wait.
Thank you.
Thank you.
It might be nice to be able to put a closing time in - and don't let people submit songs that would last past that closing time.
