program not opening
program not opening
i was using an older version and i went to upgrade. now when i double click on the programs icon, the icon appears in the dock breifly then dissapears and will not open. any suggestions? thanks.
2 things
1) if you look at your console log, it will tell you stuff that you might be able to figure out what to do yourself
2) if not, send me the console log. This is always the answer "send me the log file"
Here's how to send the log file.
thanks for the quick response!
here is my console.log
Jun 3 19:12:44 kevin-cs-imac-g5 crashdump[1103]: kJams Lite crashed
Jun 3 19:12:44 kevin-c-imac-g5 crashdump[1103]: crash report written to: /Users/kevinc/Library/Logs/CrashReporter/kJams Lite.crash.log
dyld: Symbol not found: _lame_fwrite
Referenced from: /Applications/kJams Lite.app/Contents/MacOS/kJams Lite
Expected in: /Library/Frameworks/LAME.framework/Versions/A/LAME
Jun 3 19:12:55 kevin-c-imac-g5 crashdump[1105]: kJams Lite crashed
Jun 3 19:12:55 kevin-c-imac-g5 crashdump[1105]: crash report written to: /Users/kevinc/Library/Logs/CrashReporter/kJams Lite.crash.log
you need this
http://www.kjams.com/wiki/Lame
Yes you need this particular one, you can NOT use a Lame installation from someone else, tho mine will be compatible with others.
