Hi Dave
So, we have a new MacBook Pro with El Capitan 10.11.4 preinstalled from Apple
Migrated everything over from previous MacBook Pro via Time Machine backup
Can't get my beloved kJams Pro to startup, can't get it to completely crash so I can send you a report, spinning wheel keeps on turning, turning, have to force quit in Apple Menu
Thoughts?
kJams Pro crashes in El Capitan (10.11.4)
Re: kJams Pro crashes in El Capitan (10.11.4)
Did you update to latest? (get it from the web site if you must)
Also, try using the Crash kJams script, which should force it to crash, which will then allow you to send a report.
Also, you may have a settings or daemon conflict.
Try making a brand new account and running kJams from that. If it runs, something in the migration changing library settings is probably causing the issue.
