Only sound but no video on TV
Kar@NL
Post by Kar@NL »
Hello everybody,
Tried to display the karaoke video on my TV using the AppleTV with Airplay.
The sound is heard, but no video is seen.
iTunes on the other hand does display video + sound.
This is my setup:
Kjams Lite v1.0.1b81
Imac late 2013 with OSX Yosemite 10.10.5 (including latest updates)
AppleTV3 (A1225) with the latest updates
Network is wifi 802.11n/ac (transmission speed approx. 215 Mbps)
Tried several solutions but none seem to work...
I would really appreciate some advice !
Re: Only sound but no video on TV
so you're using the AirPlay menu in the menu bar?
and you're using "extended desktop" ?
what's the error?
Kar@NL
Post by Kar@NL »
Yes, indeed I'm using Airplay via the menu bar and in missioncontrol I've deselect 'Displays have separate spaces' (Sorry, don't know if this is the same text in English as I am using a Dutch version of Yosemite). And 'extended desktop' is selected.
What I do notice, is that I can't move my mouse over the TV screen, the extended desktop, is this normal?
no, it's not normal.
have you set up the virtual displays so that they match your physical layout?
eg: if the TV is physically to the left of your computer screen, did you set up the virtual displays to the TV *appears* to be to the left of the computer screen? (in Display Prefs->Arrangement)
in any case, this doesn't seem to be about kJams. I'm not sure what is going on, but once you get the AirPlay figured out, kJams will work just fine with it.
