Hi Dave,
Is there a way to adjust the volume level of individual tracks? I have a few that are very low compared to the majority.
I searched the wiki, but couldn't find anything.
Cheers,
Tez
Individual song volume levels
Re: Individual song volume levels
You can also run all your tracks through:
http://mp3gain.sourceforge.net/
or
http://homepage.mac.com/beryrinaldo/Aud ... acMP3Gain/
This will normalize across all tracks, and allow you to leave your volume set as it is.
This process happens inside the MP3, is lossless, and reversible!
or
how can recompressing an MP3 file be lossless?
It is because it is not recompressing the MP3. Instead it is doing a neat trick with the later ID3v2 standard which incorporates metadata that gives the ability to store a track relative volume adjustment. MP3Gain uses a statistical analysis to determine the correct gain to apply to each track.
http://replaygain.hydrogenaudio.org/contents.html
(with source!)
Cool right?
(with source!)
Cool right?
Interesting but does QuickTime automatically use this info on playback or do I need to update kJams to take advantage of it?
Dave:
As far as I know, QT will do playback just fine. Here is some additional info. The main page is here:
http://mp3gain.sourceforge.net/download.php
In particular, here is the C++ source:
https://sourceforge.net/projects/mp3gai ... p/download
Here is a link to the mac version, MacMP3Gain, which is a GUI wrapper around the CLI version:
If this could be put into kJams, well, um, wow!
yeah that'd be a 2.0 feature
