Tricerasoft driving me nuts
I put a live Tricerasoft ID number where required in kJams, but I when I'd done it the number of tracks available didn't show in "edit gift pack settings". I thought the problem might be, that Tricerasoft didn't like the same ID number being used on different computers, (I bought the gift package on another computer and I've used it on two computers). I then bought another gift pack and successfully bought a track.
I then got an email that said I had 74 Songs left. When I tried to buy a second track I got the window below
I've just tried again today and now I'm getting the message that I have no credit
I also updated to the latest version of kJams before trying again
Re: Tricerasoft driving me nuts
I assume by that you mean a "Gift Pack ID" number?
but ... the number of tracks available didn't show in "edit gift pack settings"
by that i assume you mean that "Gift Pack Credits" shown underneath the button "Edit Gift Pack Settings…" did not update?
if so, it means that your "Gift Pack ID" was not valid for kJams or that it was typed wrong, or the name was typed wrong. Gift Packs used within kJams must have been bought specifically for kJams, you can't just go to the TriceraSoft web site and get *any* gift pack, it must be a "kJams Gift Pack" only.
The error with the "errSSLCertExpired" will likely be fixed soon, this is not your fault or problem, it is a problem on the server side.
check the "Gift Pack Credits" again, in your prefs. what does it say?
It was a Gift Pack ID number
I did mean Gift Pack Credits
The gift pack was bought via kJams and I copied and pasted the iD number.
I bought a track using this ID and when I tried to buy another I got the window with errSSLCertExpired
I'll look at the prefs tomorrow.
k, keep me posted
Here's a shot of the prefs:
in the future:
1) please use .png files and not .tiff files (tiffs do not inline, i've converted them for you)
2) please activate the window (bring it forward) before taking a screen shot of the window. both of your shots show the window deactivated, so it's impossible to see which controls are enabled
please click "edit gift pack settings" and take a screen shot of that.
Hope this helps
no, i need you to click on "Edit Gift Pack Settings" and show me that.
also, send me a private email with your actual gift pack ID, and i'll try it here
I've sent the email, I'm going to the venue where I'm having the problem and I'll send what you need, I'f I can't get online I'll send it tomorrow
k, i'll look for it :)
Here's the screen shot
Okay, well, your screen shot looks correct. I got your email with your GiftPackID, and I tried it here, and it worked just fine!
When i enter the info in the Gift Pack dialog, immediately the credits shows updated, "Gift Pack Credits: 74".
Do you have a firewall? try turning it off. if you still have trouble, please call me during office hours and i'll poke at it myself.
I'll check the firewall but I'd be surprised :o if it's that because it worked on that computor once...but I'll check
Don't have any firewall on. I'll get in the phone to you
yeah, call tonight
